Key switch
Mike PEI
Hi Mike
the Bolts are a bit difficult to get to put is doable with long extension usually you can take apart the switch and clean up the contacts and it will be fine.
I just had Mine apart and it cleaned up pretty good. It was intermittent in the on position it looked like some sort of insect was trying to make a home in there.
All good now I am in Dieppe NB if you are stuck
Herman
