vulcanb822 Posted March 22, 2021 Share #1 Posted March 22, 2021 Hello all. I made the rookie mistake of not paying attention and photographing as I took off housing to replace battery. I reinstalled a new battery but can't remember the order where stuff was located. Attached are the pictures of what I am trying to reassemble. Link to comment Share on other sites More sharing options...
Bob K. Posted March 22, 2021 Share #2 Posted March 22, 2021 See if this pic helps. The plastic base plate slides under the rubber strap. The main fuse then slides down onto the little tab on the left. The cruise control fuse attaches to the right of the flat base plate. The fuse box goes in the middle. Link to comment Share on other sites More sharing options...
vulcanb822 Posted March 23, 2021 Author Share #3 Posted March 23, 2021 A picture is worth a thousand words. Thanks so much. Got it back together. Here's the after picture. 2 Link to comment Share on other sites More sharing options...
