BigSkot Posted July 22, 2019 Posted July 22, 2019 Went to transfer the title today on my 06 RSTD and they wanted the engine code. I looked under the engine block, on the right side, and finally found a code stamped into the engine on the left side above the foot shifter. Stamped into the engine is “P603E-014771”. Is that the engine code?
Du-Rron Posted July 23, 2019 Posted July 23, 2019 Went to transfer the title today on my 06 RSTD and they wanted the engine code. I looked under the engine block, on the right side, and finally found a code stamped into the engine on the left side above the foot shifter. Stamped into the engine is “P603E-014771”. Is that the engine code? Thats it!
