Huked Posted April 18, 2016 Share #1 Posted April 18, 2016 This is just a quick look at one of my Mods. As I was unable to get my Audio or my CB to work, I removed/replaced my audio and removed my CB. When I was removing the CB I had an idea. At first I just wanted to flip the black box upside down as to access it from the bottom, but the trunk would not fit. After looking at it I then flipped it as well as installing it under the bracket rather then on top like normal. The bolts are now going from the bottom up rather then top down, so I added an extra nut and Loctite to secure. There is a hole where the wires passed through that I will be filling in at some point. I have plans to put a set of keys and some emergency cash in a ziplock bag and possibly with other items. I also plan to seal it shut with a small bit of RTV, as I do not plan to open it once shut unless needed. This should prove to be a nice water tight Hidey Hole. Link to comment Share on other sites More sharing options...
