Patmac6075 Posted January 30, 2016 Posted January 30, 2016 As the title suggests, I'm preparing to order parts for a complete brake system rebuild. It looks as if I need two front caliper rebuild kits and they are the identical parts numbers, and one rear caliper rebuild kit which will be a different part number, but both front and rear use the same brake pad? Somehow I thought I read somewhere that one front and the rear calipers where identical, and the other front caliper (controlled by the hand lever) had its own part number.....? I'm so confused.... BTW, this is for my XVZ1200 Royale. Definitely more questions to come....thanks
