bwk Posted August 16, 2015 Posted August 16, 2015 Is there any Handlebar risers that will work on RSTD without changing a bunch of stuff??
Freebird Posted August 16, 2015 Posted August 16, 2015 There aren't many options and most are best done with longer cables. You will see some that have replaced the cables and some who do not. It is possible to re-route cables and make them work and that what some have done. The best way is to replace the cables with some that are 2" longer though.
ToyOdie Posted August 16, 2015 Posted August 16, 2015 If your looking to get your bars a little closer, I recommend the Venture risers with a 1 1/2 inch riser extension. This is what I did and it worked great. I didn't have to change any of my cables. The other advantage to this setup is it allows you to install a Batwing Fairing. Here is a link to DarrenGT where he did the same thing http://www.venturerider.org/forum/showthread.php?56020-Time-to-start-Tearing-into-the-Bike&highlight=tearing+bike.
