Guest Sponge Bob Posted April 3, 2008 Posted April 3, 2008 I just purchased the Genisis Flat LED (Custom Dynamics) turn signals for both front and back on my 05 RSV, as well as their 4 amp. load equalizer. I am assuming that the wiring harness from the rear turn signals goes under the seat. What colors are the wires for both the left and right rear turn signals? I am adding a load equalizer to this set up and need to know what wires to tap for both the rear turn signals. Any help will be greatly appriciated. I can do most things on the bike however I need a little help from time to time, and this is one of those times. Sponge Bob Tucson AZ It's a dry heat:confused24:
Guest tx2sturgis Posted April 3, 2008 Posted April 3, 2008 Hey Bob, there is a connector under the seat that feeds the rear lighting...its off-white in color, behind the battery, near the rear fender, and I think it has about 4 or 5 wires...anyway, the brown wire should be your left turn signal and the green should be the right. But make sure with a test light, just in case. Where are you planning on mounting the load equalizers? They get pretty warm. Dont mount them where they can touch the underside of the seat!
