Great White Posted May 16, 2015 Share #1 Posted May 16, 2015 Here's the story: Swapping an 86 cluster into my 83. Figuring out the wiring change is no trouble for me, but my 83 only has a neutral indicator and the 86 has gear postion. So I need the sensor from the crankcase for gear position. Anyone got one they are willing to part with? Cheap? Link to comment Share on other sites More sharing options...
flyday58 Posted May 17, 2015 Share #2 Posted May 17, 2015 I got one off ebay for $15.50, shipping included. Did the same swap you're doing. Link to comment Share on other sites More sharing options...
Great White Posted May 17, 2015 Author Share #3 Posted May 17, 2015 I got one off ebay for $15.50, shipping included. Did the same swap you're doing. Any words of advice on the swap or it just tracing wires and changing ends terminals? Link to comment Share on other sites More sharing options...
flyday58 Posted May 17, 2015 Share #4 Posted May 17, 2015 I bought an 84 cruise harness (41R) by mistake, about the first thing I got for the bike restoration. So it had the connection for the gear position indicator already. For me it was plug-and-play. My cluster is either an 84 or 85, don't remember which. But once the harness was in I just had to do the indicator swap. If you've messed with the clutch slave cylinder at all you know it's tight in there. But it's do-able. Link to comment Share on other sites More sharing options...
Great White Posted May 17, 2015 Author Share #5 Posted May 17, 2015 (edited) Bought a used indicator off ebay for 18 buck plus shipping. Cost more for shipping than it did for the indicator....just one of the costs of living in Canada.... Has a crack in part of the plastic at one of the screw points, but a little light work on the lathe and I'll have a better than new retainer for the assembly. Edited May 17, 2015 by Great White Link to comment Share on other sites More sharing options...
