Mr_D Posted April 23, 2015 #1 Posted April 23, 2015 Will a heel toe shifter fllor boards from an 86 mk2 fit on an 83 MK 1 Found a set locally but not sure if they are the same?
Mikealiasmike Posted April 23, 2015 #2 Posted April 23, 2015 I did some research on here http://www.yamahapartshouse.com/?utm_source=bing&utm_medium=cpc&utm_campaign=Yamaha%20Parts%20%28Optimized%29&utm_term=genuine%20+yamaha%20parts and from what I could tell, they are different part numbers. Someone on here with 1st gens I'm sure will know far more than I could help. Good luck. Mike
Prairiehammer Posted April 24, 2015 #3 Posted April 24, 2015 Will a heel toe shifter fllor boards from an 86 mk2 fit on an 83 MK 1 Found a set locally but not sure if they are the same? I am going to say, yes, but only because when comparing mounting brackets intended for each version, the brackets appear to bolt onto the frame in the same locations and configuration. The actual footboards are different in appearance, but that probably shouldn't change the mounts. Do you know the brand of the heel/toe floor boards? VentureLine? MC Enterprises? Markland?
