Will a heel toe shifter fllor boards from an 86 mk2 fit on an 83 MK 1
Found a set locally but not sure if they are the same?
I am going to say, yes, but only because when comparing mounting brackets intended for each version, the brackets appear to bolt onto the frame in the same locations and configuration. The actual footboards are different in appearance, but that probably shouldn't change the mounts.
Do you know the brand of the heel/toe floor boards? VentureLine? MC Enterprises? Markland?
