ibsaw Posted January 9, 2007 Posted January 9, 2007 how in the heck do i install grips do i need a new throtle sleeve
dray Posted January 9, 2007 Posted January 9, 2007 i dont have a venture i have a v star classic i heated the grips with a hair dryer and twisted them off and put the new ones on but im sure you will get some one to answer with a venture soon:080402gudl_prv:
Snarley Bill Posted January 9, 2007 Posted January 9, 2007 how in the heck do i install grips do i need a new throtle sleeve just took a set of kuryakyn grips off my warrior.don't really like them.too fat.anyway when you get them they come with a throttle sleeve already installed.don't use the kuyakyn glue.you will never get the left grip off without ruining it.i ruined mine.use paint thinner inside the left grip to slide it on on and work fast.don't use lacquer thinner.you can also use dishwashing detergent and water.i've removed alot of grips over the years and never had a problem ,but the kuryakyns were a bear.the end of the grip has a plate with 4 hexhead screws.you may be able to use your stock weights if you remove this.,not sure.
