jdog910 Posted March 30, 2015 Share #1 Posted March 30, 2015 I am adding the MAP sensor to the TCI but there is no wire on pin17 in the unit i have, even some of the colors are not the same as in the instruction post picture... anyway, does anyone have any ideas? Ive emailed ingntech but no response. Thanks!! Link to comment Share on other sites More sharing options...
dingy Posted March 30, 2015 Share #2 Posted March 30, 2015 Send me an address and I will mail you some connectors that are attached to terminals already. I buy extra wires from Ignitech when I buy TCI's that I sell. I have Green, Blue, Gray, White with Red tracer and White with Blue tracer. The terminals are fussy about needing proper crimp tool being used. Fitment into 20 pin connector is tight. Or I can send you a few bare terminals, your choice. Gary Link to comment Share on other sites More sharing options...
jdog910 Posted March 30, 2015 Author Share #3 Posted March 30, 2015 PMed you THANKS!!!!! Link to comment Share on other sites More sharing options...
dingy Posted March 30, 2015 Share #4 Posted March 30, 2015 I sent you PM. Attached is wiring diagram for harness that I modify & sell with TCI's. Be very sure of connections to MAP sensor, if hooked up incorrectly, it will render MAP sensor unusable, I have learned this the old fashioned way. Without knowing details of MAP sensor you purchased, I can not promise attached wiring diagram is accurate for connections to your MAP, so treat is a reference drawing. Refer to Manufacturer specs for required connections. GaryVenture Ignitech supplied harness wiring.pdf Link to comment Share on other sites More sharing options...
