Droneh8tr Posted March 11, 2015 Share #1 Posted March 11, 2015 (edited) So my engine is nearly back together. Its time to time the rear cylinders. #1 cylinder is at TDC Cams have been laid in position... Yes I know the chain isn't on them.. The exhaust cam, small hole, lines up with the mark on the boss perfectly (left cam) The intake cam WONT line up. The intake lobes for cylinder 3 are hitting the buckets. This is as far as it will go. Any idea whats going on? Does anyone know how to time the cam without the small hole lining up? I've spotted that the transmission issue was resolved awhile back. Maybe during that opening of the engine things were swapped out and now aren't exactly how their suppose to be. Just a thought. I've ridden this bike maybe 4000 miles before I opened the engine so I know, somehow, it can be timed. [ATTACH=CONFIG]98034[/ATTACH] Additional info... The front cylinders intake cam is the same as the rear. It won't line up either. OK, I think I may have figured it out.. I'll feel kinda dumb if this is the case, but oh well.. I'm humble. The cam is only suppose to line up by turning the cam and compressing the valve springs.. The exhaust does not have this issue. It will line up without compressing any valve springs. If someone will confirm if I'm right I would appreciate it.. I want to get this engine back in the frame. Edited March 11, 2015 by Droneh8tr Link to comment Share on other sites More sharing options...
Venturous Randy Posted March 11, 2015 Share #2 Posted March 11, 2015 I hope when you removed the cam caps that you numbered them so they will go back in their original positions. They were linebored with the caps torqued down before the cams were installed Also, the cam on the left does not look like it has a good surface where the cap goes. It may just be the picture. Randy Link to comment Share on other sites More sharing options...
Droneh8tr Posted March 11, 2015 Author Share #3 Posted March 11, 2015 I hope when you removed the cam caps that you numbered them so they will go back in their original positions. They were linebored with the caps torqued down before the cams were installed Also, the cam on the left does not look like it has a good surface where the cap goes. It may just be the picture. Randy Oh yeah... everything was marked and is going back in its original spot.. I think what your seeing is grease. The surfaces on everything is good. Link to comment Share on other sites More sharing options...
dingy Posted March 11, 2015 Share #4 Posted March 11, 2015 I attached a picture of the front & rear heads with cams in for a reference point. There is one way to time cams, you must use small holes for reference on rear head & large hole for the front cams. Only way the shim bucket could touch cam is if a shim is not installed. Gary1986-1993-Yamaha Venture Cam install.pdf Link to comment Share on other sites More sharing options...
