Broncoboy36081 Posted September 18, 2014 Posted September 18, 2014 Well already talked to another member about this but since I added some coolant I have about a quarter size spot on the ground after a good hot ride. It's not coming from the freeze plugs or the Twinkie. Only thing I know is that I might have overfilled it. That's what the other member said as well. The leak is located around the kickstand. Can't see where it's coming from but I am with the other member. Any other scenarios or possibilities would be nice to know.
Seaking Posted September 18, 2014 Posted September 18, 2014 Well already talked to another member about this but since I added some coolant I have about a quarter size spot on the ground after a good hot ride. It's not coming from the freeze plugs or the Twinkie. Only thing I know is that I might have overfilled it. That's what the other member said as well. The leak is located around the kickstand. Can't see where it's coming from but I am with the other member. Any other scenarios or possibilities would be nice to know. The drain line from the holding tank comes down by the kickstand area.. Best guess is simply an overflow drip.. But best keep an eye on the reservoir level. Mine did that after I did a coolant flush then stopped weeping onto the floor after a couple of rides.
