Razorback Posted May 22, 2014 Posted May 22, 2014 Looking at a coworkers bike and the left antenna will pull right out of the base, while the right one feels secure. It looks like a black plastic part on the bottom of the antenna base fits into a metal receptacle on the bike. The metal part has indentions 90 degrees apart. I looks like the black part on the antenna may have had lugs at the same points. How does it work and go together? Is the loose antenna trashed? thanks
eusa1 Posted May 22, 2014 Posted May 22, 2014 Put some epoxy around the outside area of the black plastic and push it back into the collar, it will be fine.
Freebird Posted May 22, 2014 Posted May 22, 2014 What year is the co-workers bike? The '99 models had crap antennas that often did that. They changed the design in 2000.
