chaneyd Posted June 27, 2013 Share #1 Posted June 27, 2013 Have added the saddlebag trim rails on my '01 RSV but have a question concerning the reflectors. These had to come off of course but the trim rails are smaller in diameter than the crash bars. I've seen pics of other RSV owners showing the reflectors on the trim rails. Can they be adapted somehow? Thanks in advance. Link to comment Share on other sites More sharing options...
bokeifus Posted June 27, 2013 Share #2 Posted June 27, 2013 Yes, you can use them. Get you a piece of rubber hose and cut 4 pieces into 1" length. Then slit them down one side so you can slip them over the crash guards. 2 pr reflector. Then simply put your reflectors on as the reflector will now clamp onto the hose, and the hose will clamp onto the rail when you tighten the screws. i think its like 1" water hose line from the auto section at your local auto parts store. Link to comment Share on other sites More sharing options...
chaneyd Posted June 27, 2013 Author Share #3 Posted June 27, 2013 Thank you, thank you, thank you. Link to comment Share on other sites More sharing options...
dacheedah Posted June 27, 2013 Share #4 Posted June 27, 2013 or take a dremel to them http://venturerider.org/forum/showthread.php?t=64555 Link to comment Share on other sites More sharing options...
