Leadog Posted April 1, 2013 Posted April 1, 2013 Looking for a You Tube, PDF, or anything that shows a newbie how to balance carbs on my 2001 RSTD. Thanks Leadog
playboy Posted April 1, 2013 Posted April 1, 2013 Try this http://www.venturerider.org/forum/showthread.php?t=258 Lots of info for just 12 bucks a year or did you forget to renew your membership.
tazmocycle Posted April 4, 2013 Posted April 4, 2013 if you look between the front and rear cylinders at the bottom of the carbs from the right side you will see a phillip head screw, this one balances the 1&2 carbs. if you look from the left side to the right side, you will see 2 phillip head screws, the one toward the rear of motor, adjust 3&4 carbs and the front screw, adjust the 1&2 to 3&4 sets. make small adjustments as when you push on screw it'll change it a little. rev the engine a little after a few adjustments to see how their adjusting on the syncing tool. the idle should be around 1,000 rpms and will also go up or down as you make adjustments, so you may need to adjust the idle while syncing. i'm including a couple of pics of the screws on a extra set i have to let you see the screws i'm talking about. this is for the 1996- 2001 royal stars with the 28mm carbs on them. there is some differances between them and the 32mms on the 99-present ventures and 05 up tds
