screamstone Posted November 20, 2012 Share #1 Posted November 20, 2012 Hey everyone... Feedback on intercoms solved!!! Well, at least my issue. I have headsets that clip on to the helmet. There are three wires that need to be reconnected when moving from one helmet to another. They only fit one way... or so it seemed. I was getting a ear shattering feedback loop with intercoms. Happened more than once. And what I discovered was that the microphone cable from the connector can easily get connected to a speaker input! That's the issue!! No wonder I was getting feedback- check to see that you're not connecting your mic DIRECTLY TO THE POWERED SPEAKER CONNECTIONS! That'll do it every time. There follow your mic connection to the clip with the connecting wires. I'm pretty familiar with cables and fancy myself a pretty good troubleshooter, but there's something about the way that the cables are coming off of that connector with the mic attached that makes it easy to connect to the wrong spot. After you get it right. Mark the mic connectors with colored tape. Problem solved! I have a half-helmet with the speakers in the removable curtain. Removing them would cause this connection problem every time! Not any more!!! Link to comment Share on other sites More sharing options...
