PapaAl86 Posted August 14, 2010 Posted August 14, 2010 My 86vr was running good. On my way home from work.it started acting like running out of gas ,with some backfiring.I checked ohms on pickup coils & ignition coils there OK.But no spark to back 2 plugs.Any ideas would be helpfull.
safetyguy Posted August 14, 2010 Posted August 14, 2010 Have you changed your plug wires and caps anytime recently?
PapaAl86 Posted August 14, 2010 Author Posted August 14, 2010 No but ohms tested good. what I thought was strange was no spark at all on rear plugs.
safetyguy Posted August 14, 2010 Posted August 14, 2010 Have you checked the TCI connector -- maybe it is loose. A couple of other things to do -- search this forum on how to check your pickup and ignition coils with a meter. Just some random thoughts...
KarlS Posted August 14, 2010 Posted August 14, 2010 I've lost spark to both right side twice now and it's been bad TCI connection both times. I have my TCI mounted on top of the air box now (thanks to Squidly) and it just took unplugging and cleaning. Good Luck.
