Just got some new end caps that go on the end of handelbars and for the life of me can't figure out how to change them. P O scuffed up the right on pretty good and the new ones are nice and shiny. Anyone able to give me some insight on changing these buggers out?:doh:
Jim, You'll have to take the grips off the bike. The caps are held on by a phillips head screw that's accessed from the open end...
I was lucky enough to just rotate the end caps counterclockwise and they unscrewed. I KNOW they are not macho-man tight upon reattaching, but they are good enough for me. Good luck with yours!
  JimRoberts said:
Thanks Condor. Is taking the grips off as big of a pain in the butt as I've heard?
work an edge of the grip up and insert air compressor nozzle and blow. then pull. mine came right off doing that
iowa guy
