okiefirefighter Posted October 5, 2008 #1 Posted October 5, 2008 OK I bypassed the sensor with the 2.2 ohm resistor. Instead of hooking to the acc. wire, I hooked a conector to the wire and mounted it under the screw that went to the fuse that I was supposed to solder to. Is this OK? Kevin
lonestarmedic Posted October 5, 2008 #2 Posted October 5, 2008 Kevin, as long as the resistor goes from the sensor wire to a SWITCHED 12vdc you should be ok. Before replacing my fusebox, mine was on the 12vdc accessory screw. JB
