TEW47 Posted June 12, 2007 Posted June 12, 2007 If your driving light is loose I have a fix. Mine were loose and moving around alot. So I took them apart and found in the driving light there is a socket head bolt that has been drill out lengthwise. All you have to do is remove blinker light,be sure to take the bolt all the way out. Remove retaining ring on driving light and just let the light hang there for awhile. Unplug the red and the orange wires. Slowly pull the red and orange wires down just enough to get a 8mm allen wrench in. With a wrench hold the sided chrome part that you just pulled the blinker light off of and tighten with allen wrench good and tight. Push the red and orange wires back up into the driving light shell and replug them. Put light back in and the blinker light. You might won't to put some kink of thread lock on the allen bolt before you retighten it. Worked for me. Gene Weir
