Guest Wilson Posted October 8, 2006 Posted October 8, 2006 Has anyone had trouble with the little switch on the Yamaha Passing Lamps for an '05 RSTD. If so, what, and how, was the problem resolved. Thanks in advance.
BMW Posted October 8, 2006 Posted October 8, 2006 If your refering to the push button switch that comes with the lamps,I replaced mine with a toggle switch that I picked up at radio shack for under ten bucks and you can probably get one at any auto parts store, autozone, pep boys,etc.
Stoutman Posted October 8, 2006 Posted October 8, 2006 I replaced mine with one that came with the JCWhitney handlebar switches. It came apart before I finished installing the lights. I took the switch out of the circuit and used the shell to fill the hole in the lamp. I would suggest you bypass the switch and just let the lamps come on with the bike until you find a replacement. Good luck.
