Venturous Randy Posted June 25, 2007 Posted June 25, 2007 For a while now have had a skip at very light throttle, such as running at 40 mph on flat ground in 5th gear. And, as soon as I gave it any throttle, the skip went away. I have been thru the carbs, cleaned the pilot jets, synced them and replaced the plugs. This past week, I replaced the carb rubber manifold boots the carbs set on. Mine did have some obvious external cracks and the ones I used came off an 86 engine that I have and they look very good. Did not help a bit, ran exactly the same way. Yesterday morning I decided to remove all the YICS hoses and plug them. The two outer ones are easy to get off, but the two inner ones are hard to get to. I pulled one lose with a long pair of needle nose pliers, but on the other one, when I pulled it with the pliers, it tore into. This would have been easy with the carbs off, but I have already had the carbs off several times and I am tired of doing that. After I got the plugs on tight, I decided to replace the spark plugs again as I wanted to start fresh and to be able to try to get a reading on what the plugs looked like anyway. My son suggested I try the bike before I did anything else, but I did not want to get the engine hot. Well, when I pulled the back left cap off the plug, it came off the wire. Now these wires and caps were replaced a couple of years ago, so I did not expect them to be a problem. When I looked into the cap where the wire goes, there was green corrosion on the screw that screws into the wire. I cleaned it good and cut about a half inch off the wire and screwed it back together as far as it would go. It looked like the cap had not been screwed in good. I checked the other three caps and they looked good. I double checked the sync on the carbs and they were off some, so I adjusted them. I took the bike for a ride and it is running very good with no off idle skip. I am not sure whether the plugging of the YICS system was the problem or the cap problem, but at least it is running good again. RandyA
Gearhead Posted June 25, 2007 Posted June 25, 2007 Hmmm, my first reaction was, go with the obvious, it was the bad cap, except that hi-side ignition problems usually get worse with more throttle, not better... Congrats anyway! Jeremy
