mxvet274 Posted October 25, 2014 Share #1 Posted October 25, 2014 Having a hard time finding coax couplers for the antenna wire cant find any for that size of cable. What is that size called? I have went to a rubber shorty antenna with a different mount im going trunkless. Still in the process of making mine a poor mans hot rod street glide. Or can I run the new antenna cable to the radio will it plug in? Also my cruise does not work powers on but that's it. I have cleaned the switch at handle bar. Next step? Link to comment Share on other sites More sharing options...
utadventure Posted October 25, 2014 Share #2 Posted October 25, 2014 Antenna for radio only is much less sensitive than if you have a CB. For radio you can twist and wrap the cable just don't short it out and it will likely work fine. If you have the splitter still on your bike, I think it uses the motorola connector and you can get those at Radio Shack and run a new cable. Link to comment Share on other sites More sharing options...
Money Venture Posted October 26, 2014 Share #3 Posted October 26, 2014 I don't know the Venture CB, but CBs in general used the PL-259 connectors. Link to comment Share on other sites More sharing options...
utadventure Posted October 26, 2014 Share #4 Posted October 26, 2014 I don't know the Venture CB, but CBs in general used the PL-259 connectors. The original MKII design has a single antenna with a center load and the coax is hardwired into the antenna (no connector). The end in the right fairing has a Motorola connector (like for the old radio type) that plugs into the splitter. From the splitter the antenna is connector to the CB with a short cable with a PL-259 connector and the other cable goes to the radio via the multi connector under the radio control. One of best things I did was the Marshall Mod and installed two antennas and ran a cable directly to the the CB and another directly to the radio (maybe through the splitter - don't remember). If you don't have the CB it should be easy to hook up the cable to the splitter. Dave Link to comment Share on other sites More sharing options...
dacheedah Posted October 28, 2014 Share #5 Posted October 28, 2014 Suhhest the marshall mod, will improve the setup Link to comment Share on other sites More sharing options...
