VentureRider.Org Diamond R Accessories
Home Venture History VR Members Map Classifieds Links VRAwards VRPhotos VRChat VRStore Donate
Go Back   VentureRider.Org > Technical Library - Read Only > Second Gen and Royal Star Technical Library - READ ONLY! > Body, Plastic, Paint and Seats
User's Login
User Name
Password
Remember Me?
Mini Stats
Members 11,009 Entries 0
Members Entries
Threads 45,554 Reviews 0
Threads Reviews
Posts 537,332 Polls 30
Posts Polls
Content 0 Files 0
Content Files
Links 62 Ads 0
Links Ads
More...
  #1
Old 03-02-2008, 02:14 PM
V7Goose's Avatar
V7Goose V7Goose is offline
Admin/Mod - 2005 RSV
V7Goose has a Profile Picture
Supporting Member
Location: Find V7Goose on Google Maps! Ruidoso area, NM
Lightbulb Repairing Your Broken Fairing/Windshield Tabs
Trust me, if you have a 2nd Gen, you DO have broken tabs on the inner fairing where the ends of the windshield bracket SHOULD be attached! Even if your bike is quite new, they are broken. Here is a picture of what the tabs should look like - I'm holding the broken back piece to show how it would look if it was actually there:
Attachment 15890
I'm sure Yamahaha would replace the inner fairing under warranty for this, but frankly, I don't want them to rip my bike apart to do it when the new ones will just break in the first week anyway. The relatively easy solution is to make a brace that will run from the bottom screw on the speaker to the screw in the windshield bracket. When positioned correctly, this will clamp the windshield bracket against the tiny bit of the tab that remains and stop all motion.
To start with, you will need a couple of metal straps - they cannot be too thick, but must be more sturdy than hardware tape. I found this bracket in the framing section of the hardware store and just cut the two pieces off:
Attachment 15891 Attachment 15892
Put one end on the speaker screw and then cut the bracket to the exact length that will just fit under the top lip of the inner fairing. You will have to use a pair of pliers to twist and curve the strap to fit flush against the rubber grommet that holds the nut. The correct position for the windshield bracket is to have the metal piece behind the fairing tabs, and the front lip of the rubber grommet on the outside of the tab. Here are a couple of pictures of how it should be positioned:
Attachment 15899 Attachment 15898
In other words, if the tab was still in one piece, it would slide over the groove in the rubber grommet on the outside of the metal windshield bracket. You will need to make sure the windshield bracket is properly positioned on the remaining piece of the tab before you can mark the correct position for the screw hole in the new brace. Here are pictures of the brace before I cut it to length, the finished brace before mounting, and then a couple of different shots of the brace all fastened in place.
Attachment 15895 Attachment 15893 Attachment 15894 Attachment 15897 Attachment 15896
Once you have those new braces in place they work like clamps and everything is rock solid.
__________________
V7Goose - Patriot Guard Rider
Venture Riders meet on Channel 29!
Iron Horses in the stable: 05 RSV QuickSilver, 79 Guzzi G5 LAPD, 75 Guzzi Eldorado Police, 73 Guzzi Ambassador/hack
The Following 4 Users Say Thank You to V7Goose For This Useful Post:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Repairing Your Broken Fairing/Windshield Tabs V7Goose Second Generation Venture Tech Talk 17 01-17-2011 11:12 PM
broken fairing, "better than new" hipshot Watering Hole 5 03-23-2008 11:12 PM
Help with repairing torn fork tube boots? Grayghost General Tech Talk 5 10-31-2007 03:38 PM
Bag Guard Tabs DANJ First Generation Venture Tech Talk 4 06-14-2007 09:50 AM
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2004 VentureRider.org
