michaelclaw Posted March 25, 2016 Share #1 Posted March 25, 2016 Hey, So i've been looking at people doing performance upgrades on their Royal Star's and Ventures and i keep seeing people mentioning swapping cams. I decided to check on the pricing of cams and i found some cams for 60 bucks each and i wanted to know what i would need to do a cam swap and for someone to confirm im looking at the correct thing to purchase, (I'm assuming i have the purchase the front and rear?) I'm looking at these cams right now assuming they are the front and rear. http://www.ebay.com/itm/yamaha-vmax-v-max-vmx1200-inlet-in-cam-camshaft-box-316-/141821708157?hash=item21053b877d:m:mTYxRqrlRI-eeQx2RN2qXRg http://www.ebay.com/itm/yamaha-vmax-v-max-vmx1200-outlet-out-cam-camshaft-box-318-/131646425781?hash=item1ea6bd0ab5:m:mXhwxfqTOnns15zKxia9OAw I'm going to have a mechanic install them most likely. Thanks hopefully someone can help. Link to comment Share on other sites More sharing options...
Beau-Kat Posted March 25, 2016 Share #2 Posted March 25, 2016 Probably want to change the valve springs also. Link to comment Share on other sites More sharing options...
michaelclaw Posted March 25, 2016 Author Share #3 Posted March 25, 2016 Yeah i had found a post on Delphi i believe, showing what you need to order to do a camshaft upgrade. Thank you for the reply though! Link to comment Share on other sites More sharing options...
kevin-vic-b.c. Posted March 25, 2016 Share #4 Posted March 25, 2016 Yeah i had found a post on Delphi i believe, showing what you need to order to do a camshaft upgrade. Thank you for the reply though! can you please share the Delphi post Link to comment Share on other sites More sharing options...
michaelclaw Posted March 25, 2016 Author Share #5 Posted March 25, 2016 I believe this is the kit that he is referring to;Yamaha 96-98 royal star 1300 performance power kit w vmax camshafts adds 20 horse power to bike and will rev higher rpms. This is a kit designed by Yamaha to do this and these are all new and genuine yamaha parts. Kit includes these items : qty 2- 1fk-1218100-00 camshaft 2 (vmax) 2- 1fk-12171-00-00 camshaft 1 (vmax) 16- 36y-12114-00-00 outer valve springs 16- 36y-12113-00-00 inner valve springs 1- 4nk-82305-00-00 control unit These items total to roughly $1800 if purchased seperately. In order to install this kit you will need some (6) gaskets and a chain joint. I'll include a list of these part numbers along with the kit Personally I don't think that his carbs are big enough to make it perform properly Heres the link to the website aswell. http://m.delphiforums.com/vrider/messages/12818/39 Hopefully that helps! Link to comment Share on other sites More sharing options...
