I have a 2006 RSTD which is at home and I am at the beach.I want to purchase some Genisis led turn signals but do not know which base will work.Wiithout the bike I cannot take out the bulb.
1157 replaces all 1157, 1154, 1034, 2057, 2357, 2397, 3496, and 7528 bulbs
http://www.customdynamics.com/_themes/neon/neoarule.gif
http://www.customdynamics.com/Images/baz15d.jpg
Dual Intensity Offset Pins - 7225
( Used on Most New Yamaha, Honda, and Suzuki Rear Turn Signals)
http://www.customdynamics.com/Images/bau15s.jpg
Single Intensity Offset Pins - 7507
http://www.customdynamics.com/_themes/neon/neoarule.gifor
According to the service manual it take a 2 prong bulb most likely an 1157 type bulb
Ask the dealer you pln on getting the leds from if they will fail after long periods of time when being used I have seen some of them the went out after sitting in traffic
Jeff
OK, I pulled the bulbs out of my '06 RSTD. The single contact for the rear looks like it should fit. The front dual contact bulb has three side indexing pins. Looking at your top picture, there should be one more indexing pin at approx. 11 O'clock.
