American Posted May 16, 2018 #1 Posted May 16, 2018 The Star Venture rear brake master cylinder reservoir is located inside the right lower fairing. If you look at the attached photo you will see a square hole to the left of the access panel on the right lower fairing, that hole allows you to see the brake fluid level. To remove that access panel you turn the bottom screw 1/4 turn and it should pull out, then you will slide the access panel downward a little bit and it will come off, do not pull straight out on the access panel or you may break the slots that hold it in place. If you need to add brake fluid you will have to remove the access panel. To reinstall the access panel you line up the slots and slide the panel upwards a little bit and then put the quarter turn screw back in and secure it with a quarter turn. I don't know why every picture I upload gets rotated a quarter turn any clues?
