Lug Nut Posted May 3, 2016 #1 Posted May 3, 2016 1998 RSTC. Pulled the middle gear cover to look at clutch slave cylinder (leak)...found pieces of the bearing in the cover and cam see where chunks of the bearing are missing. I can order the shim, bearing, thrust washer, spring retail ers and middle drive gear nut for less than $100 so that's not too bad. Is this a hard job? Will I need any special tools?
