Evan Posted July 29, 2014 #1 Posted July 29, 2014 Thought I would mention this as it may help someone else someday. My riding mower kept stalling out. I recently replaced the fuel filter and noticed that the bowl never seemed to have as much gas in it as I thought it should. Every time I added gas, it seemed to run for a while, then stall out again when the gas level went down a bit. Decided it was becoming so annoying that I needed to check it out. Turned out that some spiders had entered the gas cap vent hole and plugged up the vent. Cleaned it out and sure enough, problem solved.
