[ATTACH]79244[/ATTACH]
[ATTACH]79245[/ATTACH]
[ATTACH]79246[/ATTACH]
[ATTACH]79247[/ATTACH]
[ATTACH]79248[/ATTACH]Hey VR members:
I recently got the Star OEM chrome rear fender tip and installed it. This was in a shed with little room, but I managed to get it done with few screw ups, and scratches.
I followed directions that were provided, but keep in mind that in addition to the saddle bags, the passenger backrest hardware will need to be REMOVED from the rear fender to gain access to where the hole needs to be drilled. This was a little time consuming, and some anxious moments as the allen bolts were red threadlocked in. Took some leverage to break loose and get off. Ditto with putting back on. Lining them back up was time consuming to assure no crossthreaded allen bolts.
One thing that I will stress- and that I did not do thoroughly enough is- TAPE OFF THE FENDER several inches HIGHER than the top edge of the chrome tip. I taped the back of the chrome tip as instructed when fitting, but the edges are so sharp that it cut the tape and eventually scratched the paint. Also, during installation, masking off the fender ABOVE the top edge of the tip is important. More on that later...
Be sure to quadruple check your marks for drilling! If you have someone that can help you with this, please employ their assistance to make sure that the chrome tip does not move when marking. I was a little off and had to use the rattail file to broaden the drill hole. During this process, I slipped and scratched the crap out of the fender, hence the MASKING TAPE ON FENDER SUGGESTION! ha! (note: the stock Yamaha color of my 2005 according to Color Rite is 0919- Bluish Gray Metallic....) Also- Remember WOOD BEHIND FENDER WHEN DRILLING. Even then, be careful not to penetrate wood with drill bit and nick the tire.
I searched and searched for the 3M gasket type, self adhesive-backed, rubber trim to put on the back of the chrome tip that was suggested by another VR member. I had no luck finding this stuff at Home Depot, Lowes, or a 3M Window tinting place? If you have the time to get it, it may be helpful with chrome to paint contact. I used Electrical Tape since I couldn't find it.
I used quick dry nail polish to prime the drilled holes.
As usual, this project took much longer than expected. My opinion for a DIYer: plan on 3 HOURS to complete due to all the hardware removal and reinstallation if you don't have the bike on a lift, have air tools, etc.
I also installed the front rear chrome tip and it was lickity split- less than an hour.
Good luck!
Edited by yuckly
Continued success! Love them![ATTACH]79250[/ATTACH]
[ATTACH]79251[/ATTACH]
[ATTACH]79252[/ATTACH]
[ATTACH]79253[/ATTACH]
[ATTACH]79254[/ATTACH]
