I installed the Custom Dynamics LED turn signals in my 2008 RSV. They work fine even the dynamic clusters in the rear. They do flash quickly and I know some like that but I want to use the equalizers to put them back to normal speed. I think I might be doing something wrong cause the lights still flash fast. I put one under the seat tied into the rear at the plug to the lights in the back. Brown and Green wires for the turn wires...right? Up front in the fairing I'm still looking for the right plug or wires... any help where they are or which plug it is? I thought I had it right but might have tied into the wrong wires. It does require both front and back be installed before they will return to normal if they are going to... right? Otherwise if it is all right and the grounds are good then I'll just have to go for a stabalizer vs. equalizers. I don't want to change out my flasher module as I like auto canceling. Any advise anyone could give would be greatly appreciated.
I installed the same lights along with the slim line signal stabilizer and they still flash fast, so I had to install the load equalizers on the rear lights, that took care of the problem
So two equalizers on the back? In series if so? I'd have to find another spot to put a second one in for the rear. I mean a place to tap into the wire and store the hot thing. I thinking I need to find the happiness that others have found with different fast flashers.
