Sideoftheroad Posted April 2, 2011 Share #1 Posted April 2, 2011 I have a Streetpilot 2730 w/ the car adapter w/ one of those round speakers in the cable. I think one of my sons got ahold of it one day and hasn't worked right since. I would keep losing power. Well I took apart the speaker housing and there are 6 wires total. 2 to the speaker (I never cared for using the speaker), 2 to that outlet that is on the side of the speaker housing (have no idea what it is so I know I won't miss it) and the power and ground wires. I completly cutoff the 1st 4 mentioned wires so you can barely see them. This just left the power and ground wires exposed. I hardwired them into the bike and now the gps works great. There was plenty of length of wire from the Garmin harness so I was able to run it down by the fork, under the tank and next to the battery where I already had a fuse box I installed a couple years ago and pick your own spot for ground. All in all it was free and I didn't have to spend $30+ for the motorcycle wire kit. Link to comment Share on other sites More sharing options...
TearlessTom Posted April 26, 2011 Share #2 Posted April 26, 2011 Thanks for the info, I have one or two of those laying around, one is broken so I may do what you did and use it for a hardwire. I don't know what the extra pair of wires would go to unless it was for a RCA plug. The $30 one you are referring to has a RCA plug to plug external speakers to. Link to comment Share on other sites More sharing options...
Sideoftheroad Posted April 26, 2011 Author Share #3 Posted April 26, 2011 No problem. It works great. Just bought a Streetpilot 2820. To me it is exactly the same as the Zumo 550 but different layout and uses the exact same cable as my 2730. Link to comment Share on other sites More sharing options...
