Air suspension
Welcome Elton,
The air ride system on the Venture Royale only operates when the key is in the acc position.
I’m 5’8” with a 30” inseam and this bike is a tad tall for me. I rarely am able to stand flat footed at a stop light. Some years back I heard tell of a member who shaved some padding from the seat to help lower the stand over height.
  • 2 weeks later...
Hi and welcome @Elton like @Patmac6075 said the key needs to be in the ACC position to activate the CLASS.  If it still doesn’t work the circuit card likely needs to be re-soldered due to cold and cracked joints.  I to have the short leg problem with a 30” inseam.  The problem with riding without air is it’s a really harsh ride.  The forks bottom out and the rear is like getting hit in the back with a hammer.  I suggest putting in progressive springs up front and alleviate the fork problem.  I’ve heard too about some folks shaving out some foam.  Recently I started wearing boots with a larger sole and that’s helped.
 I guess that would work if you had a heel/toe shifter .
  • Haha 2
