2005 Yamaha Royal Star Tour Deluxe
Hi my name is Jonathan And I'm trying to just remove my stock exhaust baffles.
They have two bolts on the side and look easy to remove, the reason I ham hear is because I am getting my carbs rebuilt and thing I need to jet them to the right specs like the mechanic says.
I have read that there no needed to be done just sinked together but I'm not sure.
Everything on the bike is stock and I just wanna do everything.
It is duel pipes since it is a 4 cylinder
So I'm looking for the base line jetting for straight pipes for the bike
Removing the buffles is not just a simple remove the screws and pull them out process.  There is actually not a real good way to do it.  Here is a pictures of the inside of the mufflers.  Most everything is welded.  You would be much better off to just leave them alone and buy a set of Harley mufflers.  A lot of people do that.
As for the jets.  It's hard to give you a answer to that one.  I think it basically just takes a lot of experimenting and I've never wished to do that.  Here is a write up that I did years ago from information provided by another member.
You can usually pick up a pair of OEM Harley mufflers (with no cat) for about $50 or less. Some have said local HD shops will almost give them away. For me, I didnt mind them around town, but on the long highway trips they were to loud for me.
