Bubba Blue Posted July 16, 2022 Share #1 Posted July 16, 2022 I’m new to the forum. I’m browsing and using “search” but not really coming across what I’m looking for Can you refer me to a popular thread that talks common slip on, intake and most importantly proven carb rejetting for stage one? Link to comment Share on other sites More sharing options...
Marcarl Posted July 17, 2022 Share #2 Posted July 17, 2022 I don't thin that there would be one given thread on all that, but you should be able to find different opinions here and there. You'll need to tell us more about your bike and exactly what it is you want to do. If it's a first gen then post in the 1st gen forum, if it's a 2nd gen then in the 2nd gen forum. Link to comment Share on other sites More sharing options...
luvmy40 Posted July 17, 2022 Share #3 Posted July 17, 2022 (edited) I assume you are talking about re jetting the carbs and modifying the intake and exhaust for "better" performance? The problem with doing that kind of thing with these bikes is getting things to run smooth across the throttle range is darn near impossible. The CV carbs are vey particular when it comes to air flow and the air box on the XVZ and XJ Yamahas, and probably a whole lot of other Japanese bikes, is designed to supply the air evenly at the needed volume and cfm. Start monkeying around with it and you will get dead spots and uneven intake due to turbulence at different speeds. There were volumes of threads on the xjbikes forum about this. people adding velocity stacks with pods, up jetting and running open drags. Some went so far as to add adjustable intake butterfly valves and manually adjusting them. All had the same story to tell. It just doesn't work well. You might get marginally "better", I.e., faster off the line or slightly higher top end by up jetting and running a high flow air cleaner at the expense of fuel economy, but these bikes already have pretty darn good performance for as big and heavy as they are. Just one guy's opinion, YMMV. ETA: You might want to talk to the guys at Ignitech about a performance programmed CDI. They are very knowledgeable about their products and our bikes. When I went with their module on my '83, they were very helpful via email. Edited July 21, 2022 by luvmy40 1 Link to comment Share on other sites More sharing options...
cimmer Posted July 21, 2022 Share #4 Posted July 21, 2022 You could also check out the Vmax forums and see what they are doing for their bikes. But the 86-93 Ventures do not share the carbs like the Vmaxs do. Rick F. Link to comment Share on other sites More sharing options...
Bubba Blue Posted July 30, 2022 Author Share #5 Posted July 30, 2022 I agree that the bike is set up best as it comes. I’m leaving it alone. Link to comment Share on other sites More sharing options...
