Genosis Posted May 15, 2022 Share #1 Posted May 15, 2022 I tried the mod to stop the battery warning light from flashing. I added a 1k resistor from the white with red stripe at the connection to the factory resistor to the battery sensor but the warning light still flashes for battery. I tried a 2k and a 2.2k and a 3.3 in place of the 1k resistor at different times but the light still flashes. It’s a 1984 venture royale any suggestion?? Link to comment Share on other sites More sharing options...
Marcarl Posted May 15, 2022 Share #2 Posted May 15, 2022 24 minutes ago, Genosis said: I tried the mod to stop the battery warning light from flashing. I added a 1k resistor from the white with red stripe at the connection to the factory resistor to the battery sensor but the warning light still flashes for battery. I tried a 2k and a 2.2k and a 3.3 in place of the 1k resistor at different times but the light still flashes. It’s a 1984 venture royale any suggestion?? If you still have the factory resistor, just use it. Hook the wire to the positive post. Do not hook up without any resistor. Link to comment Share on other sites More sharing options...
Genosis Posted May 16, 2022 Author Share #3 Posted May 16, 2022 Thanks I will give it a try. Link to comment Share on other sites More sharing options...
Genosis Posted May 16, 2022 Author Share #4 Posted May 16, 2022 Thanks that fixed it. Link to comment Share on other sites More sharing options...
