83ventureaz Posted March 25, 2022 Share #1 Posted March 25, 2022 1983 venture. When warm, falls of face with any throttle. Link to comment Share on other sites More sharing options...
Marcarl Posted March 25, 2022 Share #2 Posted March 25, 2022 Choke plunger(s) stuck in the enrichment position? Link to comment Share on other sites More sharing options...
83ventureaz Posted March 27, 2022 Author Share #3 Posted March 27, 2022 Engine generating a lot of heat first Link to comment Share on other sites More sharing options...
Pasta Burner Posted March 27, 2022 Share #4 Posted March 27, 2022 A lot of my issues came down to needing new carb sliders. Only a handful of rides since I replaced them but not an issue so far. Link to comment Share on other sites More sharing options...
videoarizona Posted May 6, 2022 Share #5 Posted May 6, 2022 On 3/26/2022 at 9:22 PM, 83ventureaz said: Engine generating a lot of heat first It's a water cooled v4. Has some heat but not excessive. Start with cold engine. Check radiator coolant bottle. Check radiator has coolant. Check to see if the bypass valve is in the run position... Not the bypass position. Under the radiator. Don't force valve. There should be a button to push in to turn... Or something like that. Don't remember and I'm not near my scoot. Check to see if fan is coming on. There usually are two switches to turn on fan, the coolant switch is up in the right side of radiator...2 wires. Don't remember if that switch turns in when grounded or with power. Try grounding switch first. Manual available for download on this site... Hope this helps... 1 Link to comment Share on other sites More sharing options...
