Bruce Bakken Posted November 8, 2021 Share #1 Posted November 8, 2021 Do I pump grease into the clutch slave fitting or something else hope I’m even calling it right That fitting under the rubber flap. Thanks Link to comment Share on other sites More sharing options...
luvmy40 Posted November 8, 2021 Share #2 Posted November 8, 2021 (edited) STOP!!!! That is a bleeder valve for the clutch slave cylinder. DO NOT PUMP GREASE IN TO IT!!!!! Unless you have removed the slave cylinder for rebuild and cannot get it apart. Edited November 8, 2021 by luvmy40 Link to comment Share on other sites More sharing options...
cimmer Posted November 8, 2021 Share #3 Posted November 8, 2021 I would suggest you download the service manual for your 1983 Venture from here.. https://www.venturerider.org/manuals/1983-1985 Yamaha Venture Service Manual.pdf This will give you the information you need on bleeding the brakes or any other service you might need to do to your bike. Under the rubber flap is a bleed valve for the hydraulic clutch. There are a few grease points on your 83 Venture but that isnt one of them. Rick F. Link to comment Share on other sites More sharing options...
Pasta Burner Posted November 27, 2021 Share #4 Posted November 27, 2021 I’ve been wondering what that fitting was for Link to comment Share on other sites More sharing options...
