Sky mousse Posted September 29, 2021 Share #1 Posted September 29, 2021 please where is turn signal fuse located and relay 1st gen 1984 Link to comment Share on other sites More sharing options...
SpencerPJ Posted September 30, 2021 Share #2 Posted September 30, 2021 Fuse is in fuse box under cover where gas cap is. Relay is up by headlight. Explain what's going on, if no blinking it could be a ground or simply a bad bulb. Link to comment Share on other sites More sharing options...
saddlebum Posted September 30, 2021 Share #3 Posted September 30, 2021 2 hours ago, SpencerPJ said: Fuse is in fuse box under cover where gas cap is. Relay is up by headlight. Explain what's going on, if no blinking it could be a ground or simply a bad bulb. Or dirty contacts in the handle bar switch which is easy to clean. Link to comment Share on other sites More sharing options...
