daincrediblecolt Posted June 12, 2021 Share #1 Posted June 12, 2021 So just bought my first venture .. very excited to say the least.. I chose this over a heritage soft tail.. So I'm wanting to change the speakers as well.as add a Bluetooth or even better a head unit were the cassete player is .. does anyone have any experience with this ? Me and the wife are ready to.ride but she wants to listen to some tunes while doing so and the am/fm.radio.isnt doing it . Link to comment Share on other sites More sharing options...
WIZ Posted June 12, 2021 Share #2 Posted June 12, 2021 Not sure if you plan to use the CB system or not, but I completely removed my stereo system and installed a blue-tooth amp. Here is the link to a discussion about it. https://www.venturerider.org/forum/topic/69258-2009-venture-stereo/?tab=comments#comment-795494 Ron 1 Link to comment Share on other sites More sharing options...
luvmy40 Posted June 12, 2021 Share #3 Posted June 12, 2021 I had planned on BlueTooth upgrade but I found just running a short aux audio cable works just fine to connect my Galaxy. Not quite as convenient but a lot cheaper and easier on the front end. This phone mount works perfectly and is solid as a rock. https://smile.amazon.com/gp/product/B088FNVGWP/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1 1 Link to comment Share on other sites More sharing options...
sleepy2 Posted June 12, 2021 Share #4 Posted June 12, 2021 I'm with luvmy40 and go with patch cord in aux plug-in with radio( can take off front fairing and y connect to plug there so radio panel can stay shut )I plan on doing this myself as I have a Sirius satellite radio I use. When FM stations fade out or want commercial free I switch to satellite. Cheaper and less work. Link to comment Share on other sites More sharing options...
MonsterBiker Posted June 12, 2021 Share #5 Posted June 12, 2021 I also recommend the aux cable. Here is my setup, I play Pandora on my phone and have the choice of playing it on the speakers or piping it directly into our helmets through the OEM intercom system. 1 Link to comment Share on other sites More sharing options...
videoarizona Posted June 13, 2021 Share #6 Posted June 13, 2021 I too went with a wire. BUT, I added a "Y" connector under the front fairing that splits the Aux input into 2 sources. I then added XM radio and Garmin gps. The gps had an sd card slot. I loaded that with a couple of thousand oldies from my collection. So now I have radio, tape deck, XM and the gps all available to listen to. 1 Link to comment Share on other sites More sharing options...
RDawson Posted June 13, 2021 Share #7 Posted June 13, 2021 I opted to use a Bluetooth 12v receiver. It’s inside the fairing and comes on with the key. It plugged into the aux plug in there. I took out the tape deck and put charge ports there. I use iPhone so I’d need adapters to be able to charge and use aux plug at the same time. Several options out there. 1 Link to comment Share on other sites More sharing options...
daincrediblecolt Posted June 14, 2021 Author Share #8 Posted June 14, 2021 Rdawson can you show me pictures of what you mean putting charging ports in cassette slot Link to comment Share on other sites More sharing options...
daincrediblecolt Posted June 14, 2021 Author Share #9 Posted June 14, 2021 On 6/12/2021 at 5:48 AM, WIZ said: Not sure if you plan to use the CB system or not, but I completely removed my stereo system and installed a blue-tooth amp. Here is the link to a discussion about it. https://www.venturerider.org/forum/topic/69258-2009-venture-stereo/?tab=comments#comment-795494 Ron Wiz .. where did u mount the amp too ? Link to comment Share on other sites More sharing options...
circa1968 Posted June 14, 2021 Share #10 Posted June 14, 2021 9 hours ago, RDawson said: I opted to use a Bluetooth 12v receiver. It’s inside the fairing and comes on with the key. It plugged into the aux plug in there. I took out the tape deck and put charge ports there. I use iPhone so I’d need adapters to be able to charge and use aux plug at the same time. Several options out there. I did the same, except turned the cassette into a storage cubby & added a phone holder that is tied to 12v inside the fairing. It has a USB charging port that I plug right into the phone. I stream either straight from tunes stored on the phone or Pandora over BT. Link to comment Share on other sites More sharing options...
RDawson Posted June 14, 2021 Share #11 Posted June 14, 2021 1 hour ago, daincrediblecolt said: Rdawson can you show me pictures of what you mean putting charging ports in cassette slot I don’t have pics with me but I gutted the cassette deck and used a parts store set that fit inside the deck case. It has a lighter plug and two USB ports. I kept the door operational so I can close it to look factory. Link to comment Share on other sites More sharing options...
WIZ Posted June 15, 2021 Share #12 Posted June 15, 2021 On 6/13/2021 at 9:00 PM, daincrediblecolt said: Wiz .. where did u mount the amp too ? I mounted the amp in the location of the original stereo amp inside the fairing. Link to comment Share on other sites More sharing options...
