Shaggy6801 Posted June 8, 2021 Share #1 Posted June 8, 2021 Just purchase and 1984 Venture Royale xvz12 it's been sitting in a barn since 09 it seems like it runs too hot to me the gauge is 3/4 of the way up and fan runs a lot even while driving is there a thermostat I looked at the radiator it seems fine the gauge runs about halfway after the sun goes down and it is much cooler outside Link to comment Share on other sites More sharing options...
circa1968 Posted June 8, 2021 Share #2 Posted June 8, 2021 I had a similar issue with a low-mileage 07 RSV that sat for a long time. In the end, the carbs were all gunked up, causing a lean running condition, which made it run hot. I believe there was also an issue with one of the diaphrams. A carb rebuild solved my problem. Link to comment Share on other sites More sharing options...
Squidley Posted June 9, 2021 Share #3 Posted June 9, 2021 The gauge on an 84 and in reality all 1st gens tend to run towards the hotter side. In reality they're not a very accurate gauge. Unless it buries itself, that sounds about normal. Make sure the coolant is topped off and the radiator is clean between the fins and run it a bit. 1 Link to comment Share on other sites More sharing options...
Shaggy6801 Posted June 9, 2021 Author Share #4 Posted June 9, 2021 (edited) Up date ,i believe i found my problem the thermostat was stuck closed. put it in a pan of boiling water and it did not open so I bent the top a little bit to let the anti freeze flow through it ,i let it run for a while temperature got just over half and the fan kicked on and it cooled itself back down thank you for the help Edited June 9, 2021 by Shaggy6801 2 Link to comment Share on other sites More sharing options...
