Squidley Posted May 6, 2021 Share #1 Posted May 6, 2021 I've been searching a bit, trying to find a thread or post of anyone who has replaced their coil or coils with something aftermarket. I still think I have an intermittent coil issue. I wouldn't mind replacing coils, but looking for a more reasonable option than mamayama. Has anyone got some input if they've done something like this? Link to comment Share on other sites More sharing options...
WIZ Posted May 7, 2021 Share #2 Posted May 7, 2021 I switched to coil over plug set up, here is a link to the discussion. Link to comment Share on other sites More sharing options...
Squidley Posted May 7, 2021 Author Share #3 Posted May 7, 2021 5 hours ago, WIZ said: I switched to coil over plug set up, here is a link to the discussion. How are they holding up? I take it that the coil is all contained in each one of the caps without the use of a separate coil body? Link to comment Share on other sites More sharing options...
Stasher1 Posted May 7, 2021 Share #4 Posted May 7, 2021 I've been wondering the same thing lately. I've had good luck with Dyna coils in the past, so that's the direction I'd be going if I knew they'd work. If they'll work properly, I can make them fit. Link to comment Share on other sites More sharing options...
WIZ Posted May 8, 2021 Share #5 Posted May 8, 2021 13 hours ago, Squidley said: How are they holding up? I take it that the coil is all contained in each one of the caps without the use of a separate coil body? They are holding up well so far. Yes the coil is contained within the caps. 1 Link to comment Share on other sites More sharing options...
