RDawson Posted April 23, 2021 Share #26 Posted April 23, 2021 I’m thinking maybe a lift for hot steel in a blacksmith shop. ??????????? 2 Link to comment Share on other sites More sharing options...
Pasta Burner Posted April 24, 2021 Share #27 Posted April 24, 2021 On 4/19/2021 at 1:20 PM, ragtop69gs said: Well, this is clearly as definitive as "which oil should I use" ! Or which tires 🙄 some things you’re better off not asking 1 Link to comment Share on other sites More sharing options...
Marcarl Posted April 24, 2021 Share #28 Posted April 24, 2021 On 4/19/2021 at 8:35 PM, Flyinfool said: Well it is obvious that you should use the same oil as I do cuz if I am using it, it must be the best..... You're wrong on that count. Not often I can catch you on that, but this time I gotcha. Best oil, and there is none other, is what may neighbours' friend uncle uses, and he uses it because his grandfather swore by it. The story behind this is, that the grandfathers neighbour always used it and never had a failed engine. That's all I can say. Well almost. I have to believe my neighbour because he is older than me, and his friend is older than him. 1 1 Link to comment Share on other sites More sharing options...
ragtop69gs Posted April 24, 2021 Share #29 Posted April 24, 2021 1 hour ago, Marcarl said: So... Whale Oil it is. 👍 Link to comment Share on other sites More sharing options...
Flyinfool Posted April 26, 2021 Share #30 Posted April 26, 2021 On 4/24/2021 at 8:28 AM, Marcarl said: On 4/24/2021 at 10:02 AM, ragtop69gs said: So... Whale Oil it is. 👍 I think he is saying that it is fresh dinosaur fat. 1 1 Link to comment Share on other sites More sharing options...
