Flash105 Posted March 1, 2021 Share #1 Posted March 1, 2021 The guy that I bought my bike from had added a xm radio and tied it into the aux on the back side of the radio somehow !! I clipped the wires and done away with the XM and have bought a bluetooth thing that plugs into the aux outlet next to the cassette player allows me to bluetooth through my I-Phone !!!! Hooks up and works but have almost no sound!! Any suggestions at where to start?? Thanks Link to comment Share on other sites More sharing options...
djh3 Posted March 1, 2021 Share #2 Posted March 1, 2021 (edited) Little Gizmo called a Boosteroo. They make a few different models. I modified mine and added a 12v wired in part for the battery so I didnt have to take things apart. I just wired it in line under the fairing. Edited March 1, 2021 by djh3 Link to comment Share on other sites More sharing options...
videoarizona Posted March 1, 2021 Share #3 Posted March 1, 2021 (edited) Did the previous owner plug in to the aux circuit or wire into it? If he used a"y" adapter and plugged into it, the plug is still there as you only "clipped the wires". The plug may be shorting the circuit. Take the fairing off, stand in front of the bike and the aux circuit is a small wire in the top left side of the radio. The radio is in the center below the windshield area.... Should be right in that area. Look for a y adapter plugged into a female minijack connector. Let's hope it's that simple. The aux circuit is a high level circuit and usually needs no amplification as long as the item being plugged in offers a line level output. Like the output of an xm radio. If your Bluetooth unit only sends out a mic(low) level signal, then yes, you need to boost the signal. Put an amp between the bluetooth and the aux circuit. Edited March 1, 2021 by videoarizona Clarify Link to comment Share on other sites More sharing options...
RDawson Posted March 1, 2021 Share #4 Posted March 1, 2021 Is there a noise filter/isolator installed? It can mute it. Link to comment Share on other sites More sharing options...
Flash105 Posted March 3, 2021 Author Share #5 Posted March 3, 2021 I fixed my problem,,, bought a FM Bluetooth transmitter!! Works fine and had volume 1 Link to comment Share on other sites More sharing options...
