Most here swap out the stock antenna for one of the CB radio brands like Wilson, K40 or Firestick. since most CB antennas mount the same you can add a fold down adapter to any of them if you so wish. Just make sure after you mount the antenna that you properly adjust its length using an SWR meter. This is a mandatory requirement for any CB whether you use an after market or OEM, they all have to be properly adjusted or matched as they say, or you could damage the CB.
For the entertainment radio any automotive or CB antenna will do in this case adjustment is not critical.
Link to post
