guns_usn_20 Posted February 18, 2021 Share #1 Posted February 18, 2021 Hello; I have a question. Where do I install the 100 ohm resistor on my bike to keep the turn signals from flashing too fast? Thank You in Advance. Link to comment Share on other sites More sharing options...
M61A1MECH Posted February 18, 2021 Share #2 Posted February 18, 2021 Here are two options; This link takes to you a product I make, you could use this harness that breaks into the wiring harness and put the resistors between the turn signal pigtails and ground. https://www.venturerider.org/forum/topic/62634-aux-lighting-harness-for-2nd-gen-venture/?do=getNewComment This link takes you to a post by Freebird that shows how to modify the OEM flasher to make it work with LEDs. Link to comment Share on other sites More sharing options...
