Alternative to Ethanol in gasoline
Now that I'm deep into my carburetor cleaning and overhauling (waiting for new needle valves at the moment), my curious mind has taken over and I've been doing a bit of research about ethanol, why we are required to use it, what it does and why its bad.  I'm sure most of you are already years ahead of me on this, but my research led me to ask  "Why in the heck isn't someone creating an alternative to this  ethanol?"   Well, as it turns out, they are: bio-isobutanol!
Bio-isobutanol has higher energy content than ethanol, is not corrosive, is not hygroscopic (so does not phase separate) and can be made from same feedstock and equipment as ethanol (different fermentation yeast and separation processes though).  There really shouldn't be any political battles from the corn belt to protect their profits, which would be a huge hurdle to overcome.
And the best news is that the EPA approved its use as a fuel additive in 2018.
We can, in part, thank the marine industry for pushing for this through gov't channels.  https://www.nmma.org/press/article/22033
I'm not too far into it yet, but wondering if other industry groups are also backing isobutanol to replace ethanol and what the chances are we'll actually see this in our fuel instead of ethanol in the near future.
Here's an interesting article from a few years ago comparing the two additives in boat engines:  https://www.boatingmag.com/replacement-ethanol/
  • Thanks 1
Link to post
WAY back when this ethanol in the gas first started, there was a hotline to call with questions and concerns. At the time they claimed there would be no difference in fuel mileage. I called the hotline and was told that there is no difference, it is a simple matter of ME not knowing how to do basic math, even after I pointed out that I am an engineer and am quite capable of calculating gas mileage. their next response is that you can not just go by the result of a single tank. I then pointed out that I have a log book where every fuel fill is recorded and tracked. I was told that there must be errors in my recorded data. I tried to explain that the simple laws of physics say that IF you use a fuel with 50% less energy per gallon then you will get 50% less work done and that means half of the fuel mileage. I was then told that the laws of physics do not apply here because they are only using 10% ethanol.......?
I did all of this on speaker phone and the whole engineering department was ROFLOL.
Edited by Flyinfool
  • Haha 2
Link to post
So I'm not an engineer but have been around motorsports for years. So different series of cars run different fuels. Some what we call "pump gas" Usually the rule states something like fuel from readily available stations or something like that. Some use special race gas like VP or Sunoco but if checked they could get disqualified. But a local track cant do that anyways. Our rules for Legends cars said something like this and gave an octane rating. I just went to the airport and bought "can gas" 110 low lead. Some run straight up alcohol. They run cooler engine temps and make plenty of power, and may make more than an equal "gas" engine. But they burn almost twice as much fuel for same distance of race. For our street use mixing ethanol creates problems because it traps water and does some really bad things. My suspicion why they dont change to the Iso stuff is cost to retrofit plants and maybe wont need as much corn or whatever they are making the ethanol from. Brazil has been on mixed fuel for years and it works for them and they dont have much problems. And they are not using up resources you can eat. They use the husks and other things
Link to post
