Hello..members. I recently started the bike for a day trip,when i turned on the radio.NO SOUND AT ALL. I put on AUX plugged in my phone NO SOUND!Removed the fairing checked the wiring,side cover checked fuses,NOTHING. The unit turns on and i can change stations...the SP lit up so i know its on speaker mode, i have no idea, your help is wanted..lolol
Link to post
  • 1 month later...
no..i checked the CB turns on and off...No sound from the CB either
You checked the fuses left side cover; sure.
But sure as I can be there is another fuse set pertaining found right front fairing bottom. Where rec/reg is.
Also toggling the talk button is a possibility.
Link to post
